A consolidated guide distilled from years of owner and DIY troubleshooting shared online.
The 2000-2004 V6 (3.2L 6VD1 and 3.5L 6VE1: Trooper, Rodeo, Amigo, Axiom, VehiCROSS,
Honda Passport) uses drive-by-wire electronic throttle control (ETC): there is no
cable from the pedal to the throttle. When the computer sees something it doesn’t like
in that system it lights a “Reduced Power” lamp, drops you to a forced idle, and in
some cases shuts the engine off, usually with a cluster of P11xx/P12xx codes. These
problems send a lot of people chasing the wrong part, because the real cause is very
often an intermittent broken wire, not a sensor. This guide lays out how the system
works and how to find the actual fault in a sensible order.
What this is (and isn’t). This is a distillation of owner and DIY experience
shared online, not official Isuzu service literature. Confirm pinouts, voltages, and
part numbers against the factory service manual (FSM) for your exact year, and work
safely. Be careful working around a motorized throttle: keep hands clear of the
throttle plate with the key on.
First: how drive-by-wire works on these trucks
Instead of a cable, an electric motor opens the throttle plate, and the computer runs a
closed loop:
- Three accelerator pedal sensors (APS) on the pedal tell the PCM how far you’re
pressing. - The PCM drives the throttle-body motor to open the plate the commanded amount.
- Two throttle position sensors (TPS) on the throttle body report the plate’s actual
position back to the PCM. - The PCM also cross-checks the MAF airflow against the commanded throttle position.
If measured airflow doesn’t match what it asked for, that alone can trigger Reduced
Power, so an intermittent MAF can masquerade as a throttle fault.
If any of those signals goes out of range or stops agreeing with the others, the PCM
falls back to Reduced Power (forced idle), and for severe faults it forces an engine
shutdown. Restarting usually clears it temporarily, which is exactly why these are so
maddening to pin down.
A couple of practical notes that come up constantly:
- After a battery disconnect or a code clear, the PCM relearns idle over a drive
cycle, so a rough or high idle right after that can settle on its own. - The accelerator pedal sensor has no simple relearn. Setting it properly wants a
Tech 2; the field workaround is to measure the three pedal-sensor resistances on the
old unit and match the new one. Installing an APS without calibrating it can cause a
high idle.
The codes you’ll see
The exact codes vary, but they fall into “real fault” and “tag-along” groups. These are
the ones that actually show up in practice:
| Code | Meaning | Notes |
| P1120 | TPS #1 circuit fault | A real/primary fault (often wiring) |
| P1220 | TPS #2 circuit fault | A real/primary fault (often a broken TPS#2 wire) |
| P1515 | Commanded vs. actual throttle position mismatch | The classic “shake the harness” code |
| P1523 | Throttle actuator control return performance | Throttle plate not moving as commanded |
| P1299 | ETC forced shutdown | Severe fault, forces the engine off |
| P1125 | ETC limited-performance mode | Tag-along: lights the Reduced Power lamp because another ETC code set |
| P1295 | Power management / MAF-to-throttle correlation | Usually tag-along with a primary fault |
The key thing: P1125 and P1295 are usually set because a primary code (P1120, P1220,
or P1515) is already set. Fix the primary fault and the tag-alongs clear. Also watch
for non-throttle codes riding along (MAF, injector, transmission, EVAP); they point
elsewhere.
What “Reduced Power” actually is
The dash “Reduced Power” lamp means the PCM has detected an ETC anomaly and dropped to a
forced idle (or, for the worst faults, commanded shutdown). Important distinction people
get wrong: a flashing check-engine light is a misfire warning, not a throttle code,
even though it tends to flash while your foot is on the gas. Don’t replace throttle
parts because of a flashing CEL (more on that trap below).
How to diagnose it, in order
- Confirm the Reduced Power lamp actually came on (not just the bulb-test flash at
startup). If it never illuminates, your TPS codes may be incidental and the real
problem is fuel, misfire, or transmission. - Watch the throttle plate move. Air tube off, key on and engine off, have a helper
sweep the pedal from idle to floor. The plate should move smoothly with no sticking
or jumping. - Shake the wiring harness at idle. This is the single most valuable test. Wiggle
the harness between the throttle body and the PCM, especially at the bend over the
valve cover, and watch for a stumble, a twitchy throttle, or a stall. Broken
conductors hide inside the insulation and look perfect from outside. - Measure at the 8-pin throttle-body connector (5 V references, signals, the ~12 V
motor pins), then trace any suspect wire back to the PCM. - Clean and inspect the throttle-body gear train and bore, and verify the TPS is
indexed correctly if it has been off. - Check grounds (the PCM ground wires land on upper intake-manifold bolts) and
reseat/clean the PCM connector pins. - Only then look at the MAF, then the pedal sensor, then (very last) the PCM.
The number one cause: a broken wire at the valve-cover bend
By far the strongest pattern is an intermittent open or chafe in the engine harness
where it makes a tight bend over the valve cover on its way to the PCM, very often the
TPS #2 return wire (commonly the green/white one). The harness on these trucks is
wrapped and mounted rigidly, and engine vibration plus that sharp bend eventually breaks
a conductor inside its insulation or chafes it through. It produces exactly the
symptoms of a failing TPS or throttle body, with no visible damage.
People found and fixed it several ways:
- Shake the harness at idle until the fault shows, to localize it.
- Unwrap and separate the wires at the bend, giving them slack and gentler routing.
This alone has cured strong hesitation/bucking. - Cut in and re-run new wires from the PCM to the throttle body, and add a clean
ground (one fix added a ground at the power-steering reservoir bracket). - Replace the whole harness with an OEM unit when it’s chafed in multiple spots.
- One owner’s permanent workaround was to splice the throttle-body end of the broken
green/white TPS#2 wire to a solid ground point to bypass the intermittent open.
A related version of the same problem: a broken fender harness support clip let the
harness weight pull on the PCM connectors and caused Reduced Power until the harness was
supported again.
Work through the causes in order
- Harness wiring (broken/chafed/stretched at the valve-cover bend). The most common
real culprit. See above. - TPS wear, contamination, or mis-indexing. Real but less common than wiring.
Cleaning sometimes helps; a worn one needs replacing. Mis-indexing the TPS linkage
on reinstall actively creates Reduced Power and rough idle, so get the spring-loaded
lever engaged correctly (people hold the peg with fishing line while bolting it up). - MAF (dirty, failed, or aftermarket). Can command Reduced Power and can over-fuel
on cold start. Aftermarket MAFs are widely distrusted here; use an OE-style sensor and
a plain paper air filter. - Throttle-body gear train sticking or carbon at the plate, especially when cold.
Clean and re-grease the gear train, clean the bore gently. - Grounds and connector corrosion. Clean the PCM grounds and reseat the connectors.
- Accelerator pedal sensor (APS). Rarely the actual cause. Rule of thumb: no APS
codes means probably not the APS. - PCM. Very rare. In documented cases a PCM swap changed nothing and the real fault
was elsewhere (injectors, wiring). Treat it as the last suspect, not the first.
A cautionary pattern worth internalizing: more than one owner replaced the TPS, the
pedal sensor, the MAF, and a used throttle body, and even rebuilt the engine, and still
had Reduced Power, because it was an intermittent wire the whole time. When in doubt,
chase wiring before parts.
High idle: a few specific cures
High idle on these came from several different places:
- A TPS adjustment many people don’t know exists: the mounting holes are slotted for
a degree or two of rotation. Rotating the TPS fully clockwise cured a years-long high
idle for one owner. - The throttle body’s idle screw (under a black plastic cap) backed off to bring idle
down. - A failed power-steering pressure switch, which signals the PCM to raise idle (many
people simply disconnect it). - General top-end cleanup: intake manifold gaskets, EGR, PCV, MAF, and the
engine-control sensors.
Specs and pinouts worth writing down
Reported by people online; confirm against your FSM.
8-pin throttle-body connector (designation E-5; 00-02 Rodeo and Trooper wiring is
identical):
- Pin 5 (Red): TPS #1 +5 V reference
- Pin 6 (Blue): TPS #1 signal (a low reading here, around 4.08 V, flagged a marginal
TPS#1 circuit) - Pin 8 (Red/White): TPS #2 +5 V reference
- Pins 2 and 3 (Green, Blue): throttle-valve motor control, about +12 V
- Pins 1 and 4: battery-voltage feed for the motor circuit
- TPS #2 wire group: green/white, red/white, blue/white (the green/white return is the
one that commonly breaks)
Throttle-valve motor resistance: about 1.3 to 1.9 ohms across the two motor pins
(open circuit means a bad motor). The motor is not sold separately; the throttle body is
replaced as a unit, and it rarely fails.
Reference voltages: the 5 V reference should read about 4.92 to 4.99 V. A low motor
voltage usually just means a weak battery, and a weak battery can itself set
TPS/Reduced-Power codes because the motor can’t move the plate.
Idle: about 800 to 850 RPM warm.
MAF: roughly 2.8 to 6.6 g/s at idle, 9 to 17 g/s at 2500 RPM.
Throttle position: about 8 to 12 percent at idle, 28 to 36 percent at 2500 RPM.
Part numbers seen: TPS for a 2001 Rodeo Sport, Isuzu 8-97254-681-0 (around $71 at the
dealer).
Grounds: the PCM ground bus reaches the engine through several wires landed on upper
intake-manifold bolts. Clean PCM and sensor contacts with a pencil eraser, not
sandpaper.
Gotchas and myths
- Replacing a TPS to “fix” a misfire introduces ETC faults. A bad TPS does not cause
a misfire. People chased a flashing-CEL misfire, swapped the TPS, and ended up with the
whole ETC code set on top of the original problem. The flashing CEL was a misfire all
along (which can destroy the cat, so treat it seriously). - It’s usually a wire, not a sensor. The list of parts thrown at these in vain is
long: TPS, pedal sensor, MAF, used throttle body, even a PCM swap and a full engine
rebuild. Shake the harness first. - Don’t sand the TPS contact board. One owner sanded the printed circuit through and
killed the sensor. - A weak battery or a corroded ground can set Reduced-Power codes all by itself,
because the motor can’t move the plate or the references sag. Rule out the simple power
and ground problems early. - Aftermarket sensors cause trouble here, MAF especially. Prefer OE-style.
- “Limp / won’t rev past 1500” without the Reduced Power lamp is probably not ETC.
That tends to be fuel or misfire. Confirm the lamp before going down the throttle path. - The throttle motor “always seizes like on GM trucks” claim does not hold up here; no
one actually fixed an Isuzu by servicing the motor.
Maintenance and prevention
- Support the harness at the fender and PCM, and inspect and re-loom the wires at
the valve-cover bend before they harden and chafe. Give them slack and gentler
routing. - Clean and re-grease the throttle-body gear train, clean the bore gently (vacuum and
a soft brush), and clean the MAF with proper MAF cleaner. - Use OE-style sensors (MAF in particular) and a plain paper air filter.
- Keep the battery and grounds healthy, since ETC leans on solid power.
- When replacing the pedal sensor, calibrate it (Tech 2, or match the old unit’s
resistances) to avoid a high idle. - A general top-end clean (intake gaskets, EGR, PCV, sensors) resolved lingering idle
issues for several people.
Credits
This guide synthesizes the collective troubleshooting knowledge that Isuzu owners and
DIYers have shared online over the years.
Owner/DIY experience, not official service information. Verify specs and procedures
against the factory service manual for your vehicle.
