Before I introduce myself, I should warn you that I use a translator; English isn’t my native language. Therefore, if anything sounds odd in my speech, it’s due to the translator.
It’s unfortunate that I have to introduce myself using a post “asking for help” with a problem, but I must.
Let me introduce myself: My name is Sergio, “Lastra” is my alias on the forum, as that’s how I’m known in the off-road world. I’m from Asturias, in northern Spain, and I have a wonderful (or so I think) 1997 Opel Monterey, which is essentially a 1997 Isuzu Trooper 3.1TD disguised with Opel emblems. Mine, like all the others, was manufactured in Fujisawa, Japan, and imported to the Opel factory in Zaragoza, Spain, where they slapped on the emblems and sold them as Opels (due to the alliance with General Motors at the time).
Let me give you some background: I’ve always been a 4x4 enthusiast. In fact, the first car I ever drove was a Nissan Patrol K160 with an SD33 engine, and there were always off-road vehicles in my family. My father had an Opel Frontera (Isuzu Amigo) that was a terrible car with a 2.3 VM engine, and my uncle had a fabulous Isuzu Trooper 2.8TD with a 4JB1 intercooler engine, which he had to get rid of and couldn’t keep. As soon as I had the chance, I bought a Nissan Patrol, which I still own, and in 2023 I acquired this Opel Monterey with a 4JG2T engine, which has given me nothing but trouble since I got it.
I’ve already gone through four turbos with this one, and it keeps breaking down. I don’t know where the problem could be. I replaced the oil lines, cleaned the oil pan and oil pickup, and checked that the internal oil passages weren’t clogged (even the metal mesh inside the fitting that feeds both the turbo and the brake booster vacuum pump on the alternator). I also removed the oil filter housing and cleaned the two relief valves.
Currently, I’m using Motul 10W40 semi-synthetic oil, and the filter is the original Isuzu one for this engine. The oil pressure at idle when cold rises to approximately 4-5 bar, and when it warms up, it stabilizes around 2-3 bar. When hot, under acceleration, it slightly exceeds 3 bar.
I drove 3,000 km with the new turbo and I’m already having wear problems in the usual place: the turbo shaft bearing. Sometimes when accelerating, the compressor wheel makes a noise rubbing against the intake housing, and it briefly starts leaking oil.
I don’t know what to do anymore. According to a local turbo expert, the engine is carbonizing the oil and possibly has a clogged or even stuck piston ring oil seal.
Since I’m going to rebuild the engine, I’d like to get some information about a modification I’d like to make. I’ve read somewhere that a 4JG2 block can be fitted with the cylinder head, injection pump, injectors, and fuel lines from a 4JB1. Therefore, using pistons from a 4JG1-T or 4JH1, I could convert the 4JG2 into a direct injection engine. Since I’m already rebuilding the engine, this is an option I’m considering because I want to increase its power, as I’m going to install larger tires, and the 4JG2 cylinder head is sensitive due to the pre-chambers.
I look forward to hearing from someone who can help or guide me.
Thanks and greetings to all!
