Hey all, glad to be over here on the new forum free from the vile corporate creatures. I had just started this thread on the old forum right as the final meltdown begun, so unfortunately this thread is gonna be a little chopped up and missing messages as I transfer it over here.
Anyways, back to the beginning, copying this over…
As the title suggests, preparing to do the 3.4 swap on the ol Rodeo. Been considering the swap for a while, and my poor old motor decided it was finally time…
RIP my old motor-
I was maybe driving a wee bit spiritedly, and somewhere close to redline there was suddenly a rather undesirable noise, followed by continued bad bad very bad noise. Despite the cacophony of noise and a sudden drop in oil pressure, it was still running ok, so I decided this was an acceptable night for this motor’s final drive annnnd just kept driving. I limped it all the way home, still running fine surprisingly.
The damage seen when I pulled the pan wasn’t all that surprising given the assault of knocking noise. As pictured, the crankshaft did not survive the ordeal. It’s so chewed down that the raised section in the middle of the journal was no longer raised, except for a little section on the top. So not only is the journal super shaved down and full of deep gouges, its also very egg shaped! The bearings that hadn’t spun had gnarly pitting going on, I suspect due to coolant contamination from the intake manifold gasket leaking into the crankcase. I had removed that oil pan before to change the gasket, and just didn’t bother to inspect the bearings? I guess I must just love self sabotage? Im sure this could’ve been avoided with new rod bearings back then, but oh well, this motor’s days were numbered anyways.
Unfortunately for me, the Rodeo is the only functional vehicle I currently own! So as a bandaid fix while I get the new engine situation sorted- I cleaned that totally trashed journal up the best I could with some super fine sandpaper, used green high temp locktight to essentially permanently glue the new bearing halves to the rod (so the egg crank journal wouldn’t just immediately spin them), and filled 'er up with the thickest oil I could find. And believe it or not, at this point I’ve put another 1000 miles on the engine like that lol. Just doin my best to shift before 3500rpm, reeaallly babying it. It still knocks when its up to operating temp, but luckily I have a short commute lol. It seems my sketchy scumbag used car dealer type repair is gonna last me until the new engine is in!
Which brings me to-
My new engine!! Yay questionable junkyard motor!
The original plan was to get whatever camaro/firebird junkyard motor i ended up with fully rebuilt, but i might not actually have to. Somehow I scored a seemingly recently rebuilt engine. This thing looks immaculate inside-
admittedly a lil crusty on the outside, but inside its CLEAN. Most gaskets seem new, looks like even the freeze plugs are new!!
and the oil that came out looked NEW
Cross hatching was still clearly visible in the cylinder walls too. For the first time in my life I might’ve gotten lucky with the used auto parts I bought!
Perhaps some poor guy wasn’t prepared for how much power their Camaro was gonna make with a freshly rebuilt motor, and only made it a quarter mile before they biffed it lol. Oorr maybe it was the 4L60E wasn’t prepared for how much power the freshly rebuilt motor was gonna make… Can’t say for sure why that Camaro was junked with what appears to be a lot of recent engine work, but I’m not sad that it happened!
Currently working on ordering new gaskets and whatnot for the 3.4. I have a 4.3 Astrovan throttle body thats gonna go on it, as well as a set of those sweet aluminum 2.8 Feiro Valve covers.
Assuming everything still checks out once the intake manifold is off, I think I’ll keep the 3.4’s stock cam and valvetrain. Honestly the 3.1 made enough power for me. My main reason for the swap isnt a thirst for more power, I just yknow, dont want a blown motor. So I’m sure the 3.4 will make me happy as is. Spending all the time and money to totally hot rod the 3.4 isnt worth it for me.
So far my list of things to do is something like-
Repaint the valve covers, bore out the intake manifold for the larger throttle body, replace most every gasket, swap over all the accessories from my old motor, do the adjustable fuel pressure regulator mod, drill and tap the new starter bolt holes, aaand a bunch of other little things.
Not 100% sure what im gonna do about the starter mounting situation yet… I have access to a drill press so Im fairly confident that with enough measurements I can make my own crummy jig, or maybe someone here would let me borrow one? (pretty please
But uhhh yeah, thats where im at so far. Any and all advice/info is greatly appreciated as always! I believe @EdMc34ZuZu you have a 3.4 swap doc you could share? I reckon I might need that, I’m only like 78% sure I know what im doing. Hopefully I’ll be out there chirpin mud-terrains with the mighty 3.4 soon enough!
